wgm 10.2 and solidworks 2013/2014
MikeMarcoux
11-Garnet
Running 10.2 M020 with SW2013/2014. We've notice an issue that the "view information" page load blank for any content, commonspace or workspace. Literally loads a blank page. Can still access actions, but can't see anything. Thoughts?
Changing the .ini file to point to IE and adding a certificate exception for our Windchill address in the browser has fixed the problem.
7 REPLIES 7
Does this only happen through the embedded browser? If you open up Windchill in a standalone browser, are you able to load the view information page?
Hi Chris,
Yes, it only happens in the embedded browser. When looking through Firefox/IE, everything looks fine.
sbaty
(To:MikeMarcoux)
Since there is a known issue similar to this with the embedded browser in Creo2 (WC 10.1), try this: Grab the divider between the navigation pane and the content pane and resize the pane or resize the entire window. Does this cause the contents to appear?
Hi Steven,
I tried it and it had zero effect. It still appears as it does in the screenshot.
sbaty
(To:MikeMarcoux)
Ok. FWIW, here was the Tech support issue I referred to: https://support.ptc.com/appserver/cs/view/solution.jsp?&n=CS176596
