Assembly cuts
SM_9575840
Assembly cuts
I am using Creo Parametric - Release 5.0 (connected) 5.0 5.0.6.0
I am not able to create the needed geometry. It seems that with the assembly feature creation selections, you are only able to remove material.
I need to have a radii at the bottom side of an extruded cut, thus, I can not create the needed geometry. Myself & others have had similar issues on other projects as well.
none
none
solid assembly features can remove material, only. That's all.
Martin Hanák
Chris3
(To:SM_9575840)
If you need to add material you should look into using inheritance models.
BenLoosli
(To:SM_9575840)
That is intended functionality and the software is working as deigned. This has been a common complaint for many years.
If this feature is a round shape, you can do it in one step by using a revolve with the radius at the bottom.
If it is a rectangular shape of an odd shape, use an inheritance feature, as Chris suggested.
