Assembly cuts
I am using Creo Parametric - Release 5.0 (connected) 5.0 5.0.6.0
I am not able to create the needed geometry. It seems that with the assembly feature creation selections, you are only able to remove material.
I need to have a radii at the bottom side of an extruded cut, thus, I can not create the needed geometry. Myself & others have had similar issues on other projects as well.
none
none
