All,
Not sure if it's do-able. Can I make a note that reads:
1. Remove burrs from f/n (item) 3.
And have the "3" report from the bom?
From what I've been reading the answer is or was NO?
Hopefully I am explaining properly?
Creo 4.
WayneF
In this duplicate idea, @mender explains that there is a certain amount of difficulty in doing this within the software
I don't believe you can use repeat region parameters (rpt.index) outside of the table and balloons.
It sure would be nice and...
