Getting error message "The section is not perpendicular in this view: select again."
ArekTRI
Hi Creos,
I am facing this error which was registered as SPR 1410164.
https://www.ptc.com/en/support/article?n=CS51439&source=SPR%20Viewer
(Getting error message "The section is not perpendicular in this view: select again." when trying to arrows in a drawing view in Pro/ENGINEER and Creo Elements/Pro)
Is this bug repaired?
Thank you.
Arek
Creo 3 user
StephenW
(To:ArekTRI)
Well, unlikely since it says it "works to product spec". Is this an offset x-sec?
Resolution
