We are aware of an issue causing intermittent login problems for some users following a recent update. Learn More
Hello all...I want to create a boundary blend or a curved plane at a distance from a surface parallel to it, so that i can extrude a certain profile up to that plane but I cant find a way how to do it..please help me out there. I am using PTC CREO 2.0
The Offset function is what you're looking for.
Change your selection filter to Geometry:
Select the surface you want to offset:
Pick Offset (Model tab, Editing group):
If it's not too complex of a surface, you get an offset at the distance entered:
If you want side surfaces, that is available in the Options tab:
Thanks for helping Sir but i actually tried that and still its not extruding upto that surface. It only lets me select the original surface geometry for extrusion and not the offset one.
The part I outlined only creates surfaces. It may require some additional boundary blends, merges and a solidify.
Without seeing the piece you're having trouble with, I may be out of suggestions.
Thanku dear. I have done it by another method. I really apprecate your help. Thanks alot
Similar to this? I am just guessing, because I am not sure I understand the question.
yeah but it wasnt the text i wanted to extrude. But i found a solution anyway
thanks
Good day Sohaib,
I am glad you found a solution to your problem and thank you for the contributions Matt Griswold
Would you mind sharing your solution with the community Sohaib Imran? I am sure many would be interested.
Best,
Toby
Sure Sir, well I did not actually took an offset of the surface as it still wasnt extruding up to that surface, i instead took an offset of the curve of that surface, extruded it to make a solid surface then mad another extrusion upto that solid surface which worked out quite well.
Yes it was a bit lengthy process but doing an offset of the surface to create a boundary blend wasnt working out for me.
Would simply using offset from flexibile modeling tab do it for you?
