How to make drawing view normal to a slanted surface?
  • February 2, 2018
  • 8302 views
Seems like this should be something that is very easy to do, but I'm having difficulty finding out how to do it.  I have an angled bracket made out of sheet metal.  There is a 45 degree angle bend and on that bend there are two holes going through it normal to the surface.  I want to have a drawing view flat on that surface so I can dimension the hole position properly.  How do I do this?
I tried creating a view in the view manager normal to the surface with the holes and saved that view, but it doesn't come up in the drawing when I try to select a view using General View. In SolidWorks this was very easy to do, but I can't figure out how to do this in Creo.
Best answer by StephenW
The easiest way is in the drawing, layout tab, auxillary view, select the edge of the part that is at the angle you want to project. Then drag the view out in the direction you want it to project.
If you have the axis showing in the drawing, you can select the axis instead of the edge.
StephenW23-Emerald IIIAnswer
jhc1-VisitorAuthor
Hmm I've tried doing that. Auxiliary view does work when I click on the edge of the flat surface, but when I click on the edge of the 45 degree bend surface then it does not pull out and won't let me create the view.
jhc1-VisitorAuthor
It was a flat edge, but it didn't work for some reason. I was able to make it work by creating a plane on the flat surface and then selecting that when creating the auxiliary view.
Thanks for your help! It led me to finding out what I needed to do.
