How to make drawing view normal to a slanted surface?
Seems like this should be something that is very easy to do, but I'm having difficulty finding out how to do it. I have an angled bracket made out of sheet metal. There is a 45 degree angle bend and on that bend there are two holes going through it normal to the surface. I want to have a drawing view flat on that surface so I can dimension the hole position properly. How do I do this?
I tried creating a view in the view manager normal to the surface with the holes and saved that view, but it doesn't come up in the drawing when I try to select a view using General View. In SolidWorks this was very easy to do, but I can't figure out how to do this in Creo.
