When exporting a cad model as a PDF U3D I select to export annotations and parameters in the content tab however when i open Adobe Acrobat reader, I cannot find the parameters. There is a side section that has property and value columns but no which part I select those columns do not populate. Where are the parameters?
Those options have been checked. It does not work when exporting from creo. I was able to use a 3d party software and that worked for the attribute. Disappointing from PTC on their lack of MBD functionality and ease of use
Take a look:
Can you please name the 3rd party application?
Tetra4d.
