Why does Creo 10 not have smt_dflt_bend_radius
TWATSONBTU
We had set the default bend radius for everyone by adding smt_dflt_bend_radius smt_thickness*0.5 to our config.pro so everyone had the same bend radius's and was more accurate on how it was built. I was designing a bunch new Sheetmetal parts only to realize the default is now .03 which cant actually be made when your are bending .25" thick Sheetmetal. So i went to check the configuration editor and smt_dflt_bend_radius now has a cross out symbol.
Is there a new way to set this so everyone has the same default bend radius so no one forgets and sends out a part that cant be made?
13 REPLIES 13
highway45
(To:TWATSONBTU)
We can't answer. Please ask in forum with Creo 10 experts.
SolidDesigner-20.5 + PE8 + PhoenixPDM + Solidworks + Blender
TWATSONBTU
(To:highway45)
I thought this was that forum. Could you point me to the correct one.
Thank you
highway45
(To:TWATSONBTU)
I don't know why PTC makes this so complicate and difficult.
You should look here:
https://community.ptc.com/t5/CAD/ct-p/cad
and then I guess "3D Part & Assembly Design" would be right.
Hi @TWATSONBTU,
I have moved this post to the Creo Parametric forum.
Anurag
BenLoosli
23-Emerald II
(To:TWATSONBTU)
That is not a valid config.pro option in Creo 9. What version of Creo Parametric are you upgrading from?
TWATSONBTU
(To:BenLoosli)
It worked in creo 8
kdirth
(To:TWATSONBTU)
It is not listed as a config option in the official list of configs for Creo 8.
configoptionspmapdf.pdf (ptc.com)
I have only seen it as a model property.
tbraxton
22-Sapphire I
(To:TWATSONBTU)
Bend Dimensions commands:
Radius—Sets the bend radius thickness and dimension location option.
Thickness—Uses a radius equal to the thickness of the sheet metal wall.
2.0 * Thickness—Uses a radius equal to twice the thickness of the sheet metal wall.
[<Parameter Value>]—Uses a radius set by the SMT_DFLT_BEND_RADIUS parameter.
About the Bend User Interface (ptc.com)
Involute Development, LLC
Consulting Engineers
StephenW
(To:TWATSONBTU)
This would be in your start part for sheetmetal parts. It's not a config option as best as I can tell (i'm on creo 6)
File - Prepare - model properties - Bends change
Its a parameter.
Hi @TWATSONBTU,
I wanted to follow up with you on your post to see if your question has been answered.
If so, please mark the appropriate reply as the Accepted Solution.
Of course, if you have more to share on your issue, please let the Community know so that we can continue to help you.
Anurag
TWATSONBTU
(To:TWATSONBTU)
Sorry all i had been super busy and hadn't had time to look into this more. I needed something that would be global so everyone in the company would have the same settings for sheet metal. I came across a page that mentioned using a template for these settings. and since we already use a template for our sheet metal that is what i did. I changed the material to CRs and set the bend radius to .5 x thickness and it worked perfectly.
I just hate that CREO likes to get rid of useful features.
RPN
(To:TWATSONBTU)
SMT_THICKNESS will reflect the current thickness of your smt component.
Set your config.pro and use a template which uses your default thickness for every user.
Hi @TWATSONBTU
Anurag
