hello everyone,
I am encountering a problem in Creo Parametric, during the creation of a sketch or an extrude. When I want to modify a distance, I double-click on the value, and a fraction of a second later it reverts to the original value. If you have already encountered this problem, I would appreciate your help.
Thank you in advance.
try solution mentioned in https://community.ptc.com/t5/3D-Part-Assembly-Design/Can-t-enter-dimensional-value-after-double-click-in-model-sketch/m-p/857392#M127906 discussion.
Thanks for this. I got this problem recently and I've been too lazy to search for a solution. Additionally, disabling all of the fancy web stuff I never use cuts down the startup time and spares me the "There's an error in a script in this page" that's often thrown by the PTC webpage. 😀
Unchecking "Expand the browser during startup" in the window settings also cleared away some startup annoyance. So nice to start Creo without a bunch of advertisement!
