Converting Assembly to Part
  • May 17, 2024
  • 6862 views
Version Creo 9
Good Morning. I received this as a step file which opens as a assembly. I am making one of the horizontal pieces about 17" longer. Because it is an assembly with no constraints already built in, I have to move and constrain all pieces next to the 17" lengthened pipe. Is there a way to just save this as a multibody part and make the change so that everything moves together?
I have tried file and save as to see if I could just output it as a part but that doesn't seem like an option. I am used to Solidworks where everything is easier. Thanks in advance
Best answer by kdirth
In the configuration editor you can select Add... and enter the config and setting.  For hidden configs you will have to type in all of the text for the name and value as they will not show up.
You can import it as a part using the hidden config option
intf3d_in_as_part YES
Put this line in your config.pro. Since it is hidden it will not show up if you search for it.
This will create a single body part. Multibody assembly to part is coming in a future release.
I am not sure any of this is exactly what you want though.
In order for there to be relative changes there needs to be constraints or parametric relationships that tie the geometry together.
Sounds to me like what you want to do is open it as a part and then use flexible modeling to make it longer. You can do that with the config option above and the flexible modeling tab.
Phil_K4-ParticipantAuthor
Thank you for replying! Yes, that is what I want to do.
Can you give me more details on the hidden config options? How do view/change them? In that area I can only see:
open config.pro in Notepad/Notepad++ and type the option manually ... see below. Save file and restart Creo.
