where is the Shaft feature in Creo 2.0
jzhang-3
Insert > Advanced > Shaft in ProE Wildfire 5 for the On Point placement option.
I wonder where it is in Creo 2.0
GabrielZaha
(To:jzhang-3)
It's not in the ribbon. You need to customize the ribbon (look under "Commands Not in the Ribbon") or to use the command search tool
9 REPLIES 9
GabrielZaha
(To:jzhang-3)
jzhang-3
(To:jzhang-3)
OK, I found Shaft by seach. Thank you very much!
Sachin
7-Bedrock
(To:jzhang-3)
Hi Jack, can you please brief what this SHAFT command does?
jzhang-3
(To:jzhang-3)
This SHAFT commond is similar to HOLE, but in opposite way. you can use Sketcher of SHAFT to draw a shaft profile (similar to sink hole profile), it is a good way to add feature to UDF'S.
Dale_Rosema
(To:jzhang-3)
Can you apply this command to an assembly?
I never tried but I expect you can't. The reason for that is that shaft it is a command that "add" material to the model, while in assemblies you can only remove material.
Dale_Rosema
(To:GabrielZaha)
I was just checking in follow up to a previous post that I had where a tube it pierce and the material is "moved". Which in modeling would most like be a feature that I was add and then subtract the middle.
http://communities.ptc.com/message/233564#233564
Thanks, Dale
https://www.youtube.com/watch?v=VNES-Cplu4Y
this are available when u activate anatomic features
