How to open external file with Mapkey
VladimirPalffy
Do you need Open external file or Run some program while you working with Creo Parametric? You can use custom key sequence.
Creo Customization: How to open external file with Mapkey (youtube.com)
Best Regards,
Vladimir Palffy
9 REPLIES 9
Cool, thanks
You are welcome
Best Regards,
Vladimir Palffy
I tried this tip to open my Chrome web browser and it works, but it does not become the main window.  On the monitor, it opens behind Creo.
Can I make it open in front of Creo?
Hi Kevin
I tried it with Chrome web browser - it is work perfect. Chrome was main opened window
(my OS - Windows 7 64bit)
Vladimir
Best Regards,
Vladimir Palffy
I see the problem.  I ran the mapkey with Chrome already open and so what happened is that a second instance of Chrome opened and did not become the main window.
If I close all Chrome windows it works as you described.
I wish the command prompt window with the black background did not stay open.  Any ideas?
Kevin
Try this to have the command prompt window close.
This example opens Google Chrome.
@echo off
C:\Users\kbradberry\AppData\Local\Google\Chrome\Application\
start chrome.exe
exit
Hi Kevin
For your mapkey you can set  and combine any of batch command (open / save / set custom variables / rename etc.) - your new mapkey Will be perfect and usefull.
In my example I want to show how you can open external file.
Thanks for comment
Vladimir
Best Regards,
Vladimir Palffy
Very cool. Thanks Vladimir. I now have a mapkey using OS script to open Microsoft Calculator.
@echo off
REM
set %windir%\system32\
start calc.exe
exit
Nice work Kevin and Thanks for sharing.
For All:
Do you need some help with Batch File Command? Click here:
Index of the Windows CMD command line or Some examples
Vladimir
Best Regards,
Vladimir Palffy
