How to setting Orbit Constraint in Creo Parametric?
TravisDesigner
Hi
I google method to set Orbit Constraint Navigation in Creo Parametric but there're no guide.
Are there this setting in Creo Parametric?
Thank
Travis
7 REPLIES 7
@TravisDesigner wrote:
Hi
Thank
Travis
please described, what is Orbit Constraint Navigation.
Martin Hanák
Hi Martin;
When you use mouse to Orbit, they will keep the ground and rotate the view around object. In other software as Fusion 360, It's called Orbit Constraint.
Hi Martin;
please try Fly Through mode.
See http://support.ptc.com/help/creo/creo_pma/usascii/index.html#page/fundamentals%2Ffundamentals%2Ffund_four_sub%2FTo_Fly_Through_a_Model.html%23 help page.
Martin Hanák
Hi @MartinHanak
Thank suggestion. I think Fly Through different with Orbit Constraint.
Fly Through is a view mode.
Orbit Constraint is normal orbit in design environment. It keep the ground stable instead of free orbit all model.
Hi @MartinHanak
please attach picture of your model and describe how you can spin it.
Martin Hanák
Hi @MartinHanak
I find this video describe different between Constrained Orbit with Free Orbit In Fusion 360
https://www.youtube.com/watch?v=bMvhdsS1n6s
Are there feature like this in Creo Parametric?
Need to learn the orbit Fusion 360? Fusion 360 has two methods on orbit that very different - Free Orbit and Constrained Orbit. I explain why this matters and how it can help you work better in Fusion 360. How do you orbit around different axis and constrain the orbit to very specific movements? ...
Hi @MartinHanak
in Creo there is no exact alternative of Constrained Orbit available.
You can limit rotation using following information.
View tab > Save Orientations > Reorient > Type = Preferences
enables you to set spin center position and orientation (if you select the right reference)
Then View tab > Save Orientations > Reorient > Dynamic orient
enables you to rotate about red/green/blue spin center axis.
Martin Hanák
