How to setting Orbit Constraint in Creo Parametric?
TravisDesigner
Hi
I google method to set Orbit Constraint Navigation in Creo Parametric but there're no guide.
Are there this setting in Creo Parametric?
Thank
Travis
7 REPLIES 7
@TravisDesigner wrote:
Hi
Thank
Travis
please described, what is Orbit Constraint Navigation.
Martin Hanák
Hi Martin;
When you use mouse to Orbit, they will keep the ground and rotate the view around object. In other software as Fusion 360, It's called Orbit Constraint.
Hi Martin;
please try Fly Through mode.
See http://support.ptc.com/help/creo/creo_pma/usascii/index.html#page/fundamentals%2Ffundamentals%2Ffund_four_sub%2FTo_Fly_Through_a_Model.html%23 help page.
Martin Hanák
Hi @MartinHanak
Thank suggestion. I think Fly Through different with Orbit Constraint.
Fly Through is a view mode.
Orbit Constraint is normal orbit in design environment. It keep the ground stable instead of free orbit all model.
Hi @MartinHanak
please attach picture of your model and describe how you can spin it.
Martin Hanák
Hi @MartinHanak
I find this video describe different between Constrained Orbit with Free Orbit In Fusion 360
https://www.youtube.com/watch?v=bMvhdsS1n6s
Are there feature like this in Creo Parametric?
Hi @MartinHanak
in Creo there is no exact alternative of Constrained Orbit available.
You can limit rotation using following information.
View tab > Save Orientations > Reorient > Type = Preferences
enables you to set spin center position and orientation (if you select the right reference)
Then View tab > Save Orientations > Reorient > Dynamic orient
enables you to rotate about red/green/blue spin center axis.
Martin Hanák
