Hello.
Can you give me advice how to verify instances of the family table using Pro/Toolkit?
Even if I retrieve and regenerate a instance, the verify status is not updated.
Verification of table instances is not supported by Toolkit or J-Link.
This is the suggested workaround for Toolkit.
I hope you know that you can run mapkey code representing interactive user action.
To know if there is Toolkit command you have to contact PTC Support.
This work! Thank you!
Also, the model must be saved and reopened. In current session an instance status is not updated in GUI.
