Hi
I don't whether this question is already answered or not.
I am trying to open protoolkit API help document (index.html) located in protkdoc directory.
But everythime it fails with AccessControlException "access denied ("java.io.FilePermission" "C:\Program Files\PTC\Creo 2.0\Common Files\M070\protoolkit\protkdoc\images\PTCLOGO\ptclogo.gif" "read")"
Tried running IE in admin mode, but same result.
Can anybody help me to get this resolved. I am using Win7 64 bit. Creo 2.0 M70
the detailed log is :
Java Plug-in 10.51.2.13
Using JRE version 1.7.0_51-b13 Java HotSpot(TM) Client VM
User home directory = C:\Users\sandeep.kavade
c: clear console window
f: finalize objects on finalization queue
g: garbage collect
h: display this help message
l: dump classloader list
m: print memory usage
o: trigger logging
q: hide console
r: reload policy configuration
s: dump system and deployment properties
t: dump thread list
v: dump thread stack
x: clear classloader cache
0-5: set trace level to <n>
CacheEntry[file:/C:/Program%20Files/PTC/Creo%202.0/Common%20Files/M070/protoolkit/protkdoc/APIWizardStartup.jar]: updateAvailable=false,lastModified=Wed Aug 28 09:10:39 IST 2013,length=2459
0
# Swing Found.
CacheEntry[file:/C:/Program%20Files/PTC/Creo%202.0/Common%20Files/M070/protoolkit/protkdoc/APIWizardUI.jar]: updateAvailable=false,lastModified=Wed Aug 28 09:10:39 IST 2013,length=91030
Reseting Vectors
Error dfdasfdsfdsfsd:java.security.AccessControlException: access denied ("java.io.FilePermission" "C:\Program Files\PTC\Creo 2.0\Common Files\M070\protoolkit\protkdoc\config.TXT" "read")
Error in reading Configuration File
Error dfdasfdsfdsfsd:java.security.AccessControlException: access denied ("java.io.FilePermission" "C:\Program Files\PTC\Creo 2.0\Common Files\M070\protoolkit\protkdoc\msg.TXT" "read")
Error in Reading Message File
Errorjava.security.AccessControlException: access denied ("java.io.FilePermission" "C:\Program Files\PTC\Creo 2.0\Common Files\M070\protoolkit\protkdoc\api.IDX" "read")
at java.security.AccessControlContext.checkPermission(Unknown Source)
at java.security.AccessController.checkPermission(Unknown Source)
at java.lang.SecurityManager.checkPermission(Unknown Source)
at sun.plugin2.applet.AWTAppletSecurityManager.checkPermission(Unknown Source)
at java.lang.SecurityManager.checkRead(Unknown Source)
at java.io.File.isDirectory(Unknown Source)
at sun.net.www.protocol.file.FileURLConnection.connect(Unknown Source)
at sun.net.www.protocol.file.FileURLConnection.getInputStream(Unknown Source)
at java.net.URL.openStream(Unknown Source)
at API_DataManager.init_readAPITreeFile(API_DataManager.java:300)
at API_DataManager.<init>(API_DataManager.java:249)
at apiwizard.init(apiwizard.java:67)
at com.sun.deploy.uitoolkit.impl.awt.AWTAppletAdapter.init(Unknown Source)
at sun.plugin2.applet.Plugin2Manager$AppletExecutionRunnable.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Foreground = sun.swing.PrintColorUIResource[r=51,g=51,b=51]
I have something. I found the cause of this problem. Need to use Java version 1.6 instead 1.7. I made virtual machine based on Windows 7 with Java 1.6 and Internet Explorer 8. And all works fine.
You can download Java 1.6 by this link.
Hi Sandeep,
This issue may occur due to Changes to JRE Security Dialogs. For detailed information refer below articles.
https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS130577
https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS133402
I hope this will answer your query.
Mahesh
Hi Mahesh,
Thanks for reply. The links provided talk about JRE 7 Upate 21 and Update 25.
I am not aware of how to start apiwizard in webserver. But thanks for the reply.
Hi Sergey Dobrovsky,
Thanks for reply. This is a nice work around. Now I have something which I can refer to.
Hello to all
I have the same problem. Вге I do not have access to the links shown above. What can I do with Java settings to open protoolkit help? Please, anybody help me ))
Currently I don't have any solution for this. Again after Java update on my machine I am not able to access the above link.
PTC has to take some serious step to resolve this issue.
