unable to unlock protoolkit Creo 7.0.2.0
CC_10758906
I am not able to unlock protoolkit and getting error message. error attached here.
Is this need separate license or Creo license is enough to unlock?
@CC_10758906 wrote:
When I tried to unlock, I am getting this error unlocking this application requires option TOOLKIT-for-3D_Drawings.
it is simple ... your application uses functionality which requires TOOLKIT-for-3D_Drawings (FEATURE 222) -AND- you do not have license code for module 222.
Martin Hanák
7 REPLIES 7
tbraxton
22-Sapphire I
(To:CC_10758906)
A license is required. See this link for details.
https://support.ptc.com/help/creo_toolkit/protoolkit_pma/r11.0/usascii/index.html#page/creo_toolkit/get_started/Licensing_for_Creo_TOOLKIT.html
Involute Development, LLC
Consulting Engineers
unlock action is usually done be application creator.
Martin Hanák
tbraxton
22-Sapphire I
(To:CC_10758906)
Are trying to use a Toolkit app in a Creo session or are you needing to access the Toolkit API to develop a custom application?
If you need to register an application (protk.dat) then see this link. You do not need a toolkit license to register an app created using the Toolkit API.
Registering a Creo Toolkit Application
CC_10758906
(To:tbraxton)
Martin Hanák
CC_10758906
(To:MartinHanak)
Hello Martin,
You are right, after unlocking Protkunlock.bat, it is showing TOOLKIT-for-3D_Drawings not available.
You did not paint the whole picture, but I assume you are compiling with the PTC example OTK make file make_otk_examples (C++).
This links with the otk_222.lib, which requires an additional (not just TOOLKIT/OTK) PTC license (💲) for unlocking.
The solution is "hidden" in the first lines of this make file:
# ATTENTION: this makefile assumes that license 222 is available;
# to build without this license, use otk_no222.lib instead of otk_222.lib
So, in your copy of the example make file, replace otk_222.lib with otk_no222.lib, and Bob's your uncle! (unless there is something else wrong... then he is not.)
