I have a Dell T3400 workstation that has an Nvidia Quadro NVS 290 video card, we are running WF2 m180. The initial drivers loaded Pro/E ran fine, I updated to the latest drivers from Nvidia and there was strange issues when trying to move dimensions in Drawing mode. I uninstalled the updated video drivers and the problem went away. Any one using the same Nvidia card and what drivers are you on?
TIA.
Mike PaveseProducts Support Inc.
<u>http://www.productssupport.com/</u>Video drivers is a continuous issue...
Using the most recent driver may work fine. But usually the best way is to use a driver version that is at least supported, if not certified by PTC. This may be a version that old, that it is no more in the standard download sites. Try asking the graphic card vendor explicitly.
The problem is worse when using a laptop. I know what I'm talking about...
BTW: Be very careful with IntelliMouse drivers, they can really mess up ProE.
