creo 7.0 manufacturing info report missing
  • May 31, 2021
  • 4 replies
  • 4358 views
creo 7.0 manufacturing info report missing please check to attach a pic. there is no report module in the start new menu
Best answer by MartinHanak
report is obsolete. Use drawing instead of it.
We are running Creo 4.0 and when I start a new session, with the manufacturing license, I do not see any "Report" in the "File->New" dialog. Perhaps that function has been moved inside the program, to the ribbon? I notice that under "Applications", there is a "Process Documentation" choice. Perhaps that is where it went?
I have never used the reporting functions and we've been on Creo 4.0 for a while so I don't remember earlier choices.
You can still create and open reports, but you have to enable a hidden config option to do so:
"Set hidden config.pro option enable_obsolete_modes to yes"
https://www.ptc.com/en/support/article/CS235026
asifcad15-MoonstoneAuthor
Dears thanks for your replies problem solved now using drawing for reporting purpose
regards
asif
