When I go to install the trial version I get the following error: Cannot start installer Check your network connection And I have already checked all the connection and I have changed the network but it is still the same, how could I solve it
Translated the below text from Spanish to English using google translate on 10-April-2023 at 9:31am IST, by vnamboodheri
Subject: Error de instalación versión gratuita
Body: Al ir a instalar la versión de prueba me aparece el siguiente error:
No se puede iniciar el instalador
Compruebe su conexión de red
Y ya he revisado toda la conexión y he cambiado de red pero sigue igual, como podría solucionarlo
Article - "Error "Unable to launch installer. Please check your network connection" during installation of Mathcad Prime 3.1": https://www.ptc.com/en/support/article/CS257484
Similar question before:
I am having the same issue as IV_9692060, but the solutions you have posted are for the prime/paid version. Are you aware of any fixes for the free version?
There should be no difference when you install the free, fully functional 30-day version of the program.
You are right. I found this from one of your other posts, and it worked.
https://support.ptc.com/appserver/auth/it/esd/academicFree.jsp
You're welcome.
