Input/Output XMCD, MCD Converter MathCAD Express Prime7.0.0.0
HS_3223800
2-Explorer
Users are not able to access additional content in their MathCad application - Input/Output > XMCD/MCF converter. Need assistance to determine if this is a licensing issue or an application issue.
Starting from the 7th version of Mathcad Prime you can use the built-in converter (before the installation process, it is necessary to select it among the installation components).
LucMeekes
(To:HS_3223800)
There's no need to post twice. Once is enough.
To your issue:
The converter needs to be installed explicitly. You have to tick the option during installation, it is Off by default.
To correct it, de-install and re-install, while not forgetting to tick the option On.
Hi @HS_3223800,
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
Anurag
