The wizard is pretty much the same between the versions.
On "Welcome" did you select the 30-day option? Because that should have you skip the product code part, which by definition you can't fill out if you're doing the trial.
Activate your trial license - "Opening Mathcad Express Free Trial for the First Time": https://www.youtube.com/watch?v=GXlwfOPglk8
Thank you for your reply. However, the video is for PTC Mathcad Prime 7.0.0.0, it is different for 10.0.0.0, please refer to screenshot below, have to key in a Product Code, otherwise can not click Next.
After restarting and selecting the 30 days option, the Product Code part has been skipped and the license was obtained. Thank you!
