convert legacy files using 30 day trial?
JV_10350431
3-Newcomer
I am trying to convert legacy files (.xmcd) to PTC. I am using the 30 day trial. The "XMCD, MCD Converter" button is not active. Is this because it is a trial version, or is there a way to activate this feature?
LucMeekes
(To:JV_10350431)
You have to explicitly tick the legacy worksheet converter during installation, otherwise it will not be installed, and be greyed out in the interface. (see also here: https://community.ptc.com/t5/Mathcad-Installation/XMCD-convertor-not-working/m-p/785671#M1540 )
You may try to re-run the installation, to install that converter.
Is your 30 day trial still active?
Is your converter installed?
Try from here: (run converter on its own)
If your file is not a big secret then you can attach it here and I can convert.
LucMeekes
(To:JV_10350431)
The converter was not installed.  I un-installed the software and re-installed, this time clicking the converter option.  It is working now.  Thank you!
