Bode Diagram Plot
  • April 13, 2020
  • 2 replies
  • 3911 views
I am at my first steps with Mathcad, could someone help me to plot the bode diagram of the function G(f) pease
Where
and
ML
Please first enter your formulae onto a Mathcad worksheet and attach that worksheet to your posting.
I randomly established the values of the constants.
ML21-VisitorAuthor
Thanks for your answer but could you please explain how did you get the definition of the frequency range ; and some steps to plot the diagram as you did.
thank you,
Regards.
ML
You can define the frequency range taking as minimum frequency the smallest value among the absolute values of the poles and zeros and as maximum value of the frequency range, the maximum value among the absolute values of the poles and zeros. The step amplitude can be defined dividing the difference of the previous values by the number of steps. I have considered as a minimum value of the frequency Fz divided by a thousand and as a maximum value, Fp multiplied by one hundred. To have a larger diagram you can replace a thousand with ten thousand and one hundred with a thousand or ten thousand or even more, that is, they are chosen according to your needs.
