Help me mathcad prime 2.0
Athur
Hi all.
I is prolem when caculation.
Plea see picture
I is Attach File.
Thanks All
I think that you need to 'vectorise' two of your equations as attached.
Prime seems to be confused by the ho variable.
The vectorise operator can be found on the "matrices/tables" tab under the control button "vector / matrix operators"
{Would be much easier if the mathcad 15 shortcut key <ctrl> - worked}
Andy
Fred_Kohlhepp
23-Emerald I
(To:Athur)
There is a chance that Mathcad is reading the EXCEL file and importing not numbers but text strings.
Type "M =", you should see what Mathcad thinks is in variable M; if you get NaN's or numbers with quotes around them, Mathcad believes it has text, not numbers. (Same thing for the other inputs.)
Athur
(To:Athur)
Thank A Westerman and Fred Kohlhepp
I do it. verry good.
I use mathcad 15 verry good. But use prime is prolem. Thanks
