Inverse Laplace problems - MC 14 M020
tdrd
So I'm trying to get MC to find the time-response of a MDOF dynamic system (vibrations problem). I start by defining the transfer function in s-domain and then ask MC to find the inverse Laplace - it doesn't quite do it (see attached).
Interestingly, a friend reports that he DOES get a result on MC 13.
Ideas?
AlanStevens
(To:tdrd)
Seems to work if you put in a partial fraction step first.
Alan
Message was edited by: AlanStevens The float 5 I used leads to some numerical inaccuracies, which is why there are some complex coefficients in the result. Changing this to, say, float 15 eliminates the complex terms. However, there are still some small amplitude (real) terms remaining that should surely be zero. Of course, you don't need to use the float command at all!.
ValeryOchkov
(To:tdrd)
Sorry but I think answers on same questions must generate automatically - Mathcad 14/15 has new symbolic engine not from Maple but from MuPAD.
See for example http://communities.ptc.com/message/160505 and others same.
AlanStevens
(To:tdrd)
Alan
