MATHCAD Flexnet License Move
JL_1445157
2-Explorer
I'm attempting to moved my networked mathcad license to a new server. I've followed the support article  (https://www.ptc.com/en/support/article/CS20911?oskarSession=4ed21d13-73b5-4882-8e39-d12bebb4a6bc&source=support_assistant) and to how to install the service manually (https://www.ptc.com/en/support/article/CS62129?oskarSession=4ed21d13-73b5-4882-8e39-d12bebb4a6bc&source=support_assistant) and everything looks fine but when I go to start the license it won't start and when I attempt to re-read the license it fails. the Debug log isn't showing anything either.
Martin Hanák
Thank you for replying Martin!
The problem with removing my current flexnet is that it also holds other licenses for other software and that is why I opted to do the manual install.
the golden rule says that software from a certain manufacturer requires a separate installation of FLEXnet.
Therefore I suggest you install separate FLEXnet instance for PTC products.
Martin Hanák
Hi @JL_1445157,
Anurag
