Plot Question : Programming Linear or Exponential rise
Jacob_S
How  can i use programming to plot a linear or exponential  rise and decay as shown  attachment with red mark. Only for areas marked in Red
Jacob
LucMeekes
(To:Jacob_S)
I can't do programming in Prime, so here's a solution without programming.
But I'm sure you can turn that into a program.
Success
8 REPLIES 8
LucMeekes
(To:Jacob_S)
Success
Thank you for the help
ttokoro
20-Turquoise
(To:Jacob_S)
10^-6 and 10^-7 are tau of A*exp(-t/tau).
Jacob_S
(To:ttokoro)
Thank you for the details for realizing exponential  plot
ttokoro
20-Turquoise
(To:Jacob_S)
t is in second unit such as 0.000000001 s.
Jacob_S
(To:ttokoro)
@ttokoro ......I run to  trouble in inserting the function s linear(cant find in insert functions) and with exp there is a syntax error i cant figure out. Can you share your worksheet or give some tips
ttokoro
20-Turquoise
(To:Jacob_S)
See the attached file. I make functions by programming because the subject is Programming.
Jacob_S
(To:ttokoro)
Awesome...thank you
