I'm frustrated trying to simplify results from symbolic engine (new or legacy). i have tried multiple symbolic options.
For some reason, if I go in and manually do an equate, stuff sort of works?
Prime 6 file.
It's a known fact that the output of the symbolic processor is hard to control.
In your case maybe the keyword 'collect, exp' helps.
Thanks for lookig, Luc -- but your suggestion does not work.
Since you're running Mathcad 11, can the Maple engine do a better job?
Don't have it at hand.
Try 'assume,t>0'
Sadly, no again.
But again, thanks for the suggestions.
Roger
Are all your t's of the same label?
Bingo!
The first expression has the first t as "automatic" and the second t as "variable"..
Changed the first t to "variable", and all is well.
Thanks again,
Roger
