Hi, I'm currently having programming issues with converted mcxd files See attached screenshot. It's not reading PRN correctly. I have the file installed and using the read data file it finds the prn file it just won't populate the data. See attached screenshot.
Any info would be greatly appreciated. The university used to use mathcad 14 and i believe when converting the file the si units are not populating either.
Josh
It looks like you university ran a license server where you Mathcad 14 connected and retrieved its license. For some reason this server seems not to be up and running anymore. You will have to contact the IT people from your university to ask why.
Maybe the license was time limited and expired and your university can only provide a license server for Prime anymore. I can't tell.
