Werner Exinger написал(а):
Or use more than one focal point. What about a curve, where the sum of the distances from three points is constant.
WE
Nice find!
I vaguely remember having heard (a long time ago) from a Tschirnhaus-curve (but not sure - I may mix up things and be wrong about this).
Why be content with seven when you can have eleven or more ?
WE
We have 7 operators in Mathcad
1. black+blue
Nice worksheets.
I see that you, too, determine the limits of the radius L by hand (trial and error, I guess).
7. blue-root of black - with new focuses and with two branches
With two branches: one log(Black, Blue) and others log(Blue, Black):
> 5. black^blue=const
Nice, but the unit "m^m" is still wrong 😉
What about the "???"
> 5. black^blue=const
Why wrong?
I'm going to do at my dacha for a bed of flowers in the form of this oval with a physical characteristic constant 7 (m^m), not 6 (ft^m) or 5 (m^ft)!
> ??? - I do not know what is this little close curve
> Why wrong?
We had that discussion already in the other thread, so I won't repeat it here. Just one thought: (2m)^(3m) = 2^(3m) * m^(3m) = 8^m * (m^3)^m. So its NOT 8 m^m . Now do the same game with different numbers!
Why not, if a simple ellipse is not challenging enough 😉
Sorry, but its no physical characteristics and its a characteristic dealing with the numbers only, not the units. But it sure is a nice leisure activity anyway.
Obviously, if you did not make a mistake, its part of the solution curve. Just give it a try and see, if black^blue still is 4.
EDIT: There is a mistake: If L<1, then L2 would be negative and no solution exists!! But your "Coord" yields solution because L2 (as radius) is squared in the circle equation. You have to take care of this and simply let L run from1 upwards (L=1 would provoke a divison by zero, of course which could be dealt with an on error statement).
> Why wrong?
My friend in USA would like to create same bed of flowers (клумб с цветами) in his garten. He has a rule not with meter and cm but with feet and inch. I send to him the coordinate of 2 points (focuses) with feet and inch and the constant a with.... What numeric value and UNIT must I send in America? Or I must send the rule with meter and cm scale?
Better send him the ruler in metric units as your flowerbed does not scale (the property a^b=const. does not scale). And don't forget to tell him that he should only use the numbers taken w/o units when he calculates the powers 😉
You haven't answered (2m)^(3m)=? and now (6,562 ft)^( 9,843 ft)=?
Here are some curves which should scale. Simply stay with basic commutative operations + and * and simply use more points:
Here the points whose sum of distance from five points is constant:
Animation:
And here is the same with constant product of distances
Guess I have finished playing around with those curves. Can't think of a way to derive a closed parametric equation for those beasts.
Please do one more with 7 points - 7 is one fine number!
Animation
It is a lemniscate with 5 focuses - see please Лемниската — Википедия
The discription is not available in the English or German version of Wikipedia.
I am not sure if all those curves should be called lemniscates.
In the two focal point case we speak of Cassini ovals and only if the constant product is the square of half of the distance of the two focals, we speak of a (Bernoulli) lemniscate. So the two focal lemniscate is just a special case of the Cassini curves.
Bicycle Apollinaire - two branches: Black/Blue and Blue/Black:
