Simplify ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Notify Moderator
Simplify ?
Hello Everyone.
But :
To : So now the question is : " How to simplify A ? "
Thanks in advance for your time and help.
Best Regards.
Loi
- Labels:
Math Homework
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
The two expressions definitely are equivalent.
With a little help even Mathcad can show this:
The numerical evaluations are just done to check if I made any typing errors 😉
But its interesting that MC11 returns 0 when we compare the expressions while MC15 returns 1.
It may have to do with the principal value of the third root ? Not sure, though.
Are the results the same in MC11 ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
You have to face the truth - the symbolics in MC15 seems not to be capable enough to do the simplification you want to see.
Neither is the symbolics in Prime 10 - see here:
Only way to achieve the result you are looking for in MC15 seems to be as in attached, but I am sure you won't like it 🙂
Attached Sheet is in MC11 format, maybe @LucMeekes would like to give it a try with MC11/Maple.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
I guess my MC15's symbolic engine is less powerful than your .mcd file. But I guess I should like your own mcd. file :
Best Regards.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
It seems that prime 10 cannot do this:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Mathcad11/Maple:
Which means the two expressions are NOT equal.
The reason you get:
is because there's a hidden assignment (Note the redefinition indicator on A below):
behind the
The first assignment to A (very first at the top) also has a redefinition indicator, due to A redefining the unit Ampere.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
The redefinition in the hidden area was meant as a joke of mine an I also had written that MC seems to be unable to do the desired simplification and that I am sure that the only 'solution' I could think of won't make @lvl107 happy 🙂
His reply showed that he discovered the hidden area ...
Nonetheless MC15 actually claims the two expressions to be equal, even though its not able to simplify accordingly.
Find attached the original unchanged sheet of @lvl107 in MC11 format.
P.S.: Calculating the difference of the expressions seem to throw just numerical round-off errors.
Interesting is that when I use "float,200" I again get a tiny difference of about -1.6*10^201
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
It's very interesting to me !
Best Regards
Loi.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi @lvl107,
I wanted to follow up with you on your post to see if your question has been answered.
If so, please mark the appropriate reply as the Accepted Solution.
Anurag
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
They're different, because Mathcad 11 doesn't support 'rectangular':
Regarding the simplification. I guess the challenge is to find the right symbolic keyword:
Note that with 'simplify' and 'expand' I just get a big expression.
However, Mathcad11/Maple will not simplify A to the other expression. Guess that's down to the basic problem: It's hard, to impossible, to control the output of the symbolic processor.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Where does this task come from? Please name the source.
Sunday greetings, thank you.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Thank you very much. I suspected one of the many identities on the topic of "Tribonacci". OEIS is full of them. But now the solution depends on the elaborate system of equations in x and y. How did you come up with this approach?
BTW
In the graph in MC14, the green point for Y is not shown.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
The file was "Save As" as "Snub Cube _ MC13" :
___
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Please cite the source for the term A:= ... in your original post.
Sunday greetings 😉
