Strength of Rectangular Reinforced Concrete Columns (rectcols.mcd) - Thomas P. Magner
mnet
3-Newcomer
Does anybody have "rectcols.mcd" by Thomas P. Magner? It's about Strength of Rectangular Reinforced Concrete Columns. I would very much appreciate if anybody can help me with this file. I had this file but lost it. It used to be available on mathsoft's old community site.
Thanks in advance.
(To:mnet)
Often you come across broken links which point to the old mathsoft site. I like to use the wayback machine at http://web.archive.org to try to access those files or pages. It helps if you know the exact location of the file (at the times the site was active).
I had success with the file you asked for - google found at least two different links to that file and so it was easy to let the wayback machine look for the file - I had success at a snap shot from 2006:
http://web.archive.org/web/20060319154741/http://www.mathcad.com/Library/LibraryContent/rectcols.mcd
Shame on PTC for not making available those old goodies!
20 REPLIES 20
ValeryOchkov
(To:mnet)
mnet
3-Newcomer
(To:ValeryOchkov)
The worsheet in the link above is good. But I am still looking for the one by Thomas P. Magner. He did it by solving for inclined neutral axis.
Thanks anyway for the reply.
(To:mnet)
RichardJ
(To:Werner_E)
You can get the URLs for some of the files in the library here:
http://www.edasolutions.com/old/MathCad/MathCadFiles/Civil_Mechanical_Engineering.htm
(To:RichardJ)
Thats exactly one of the sites with links that google had found for me.
RichardJ
(To:Werner_E)
Ha! I found the main library page at the Wayback machine. I followed it though to some of the Mathcad files, but of course didn't try all of them.
http://web.archive.org/web/20040804121505/http://www.mathcad.com/Library/
This is the latest version of the page I can access.
mnet
3-Newcomer
(To:Werner_E)
Thank you very much for your time and effort. This is the file that I am looking for. Thanks for the tips regarding the archive. This is very helpful.
RichardJ
(To:mnet)
PTC destroyed that library. Some of it seems to have ended up in the hands of Knovel, who would charge you for it (even though it used to be free!). The rest has just gone. I think giving stuff away for free to your users just does not fit PTCs business model.
I do have the attached sheet. It's from the handbook "Civil Engineering Solved Problems". I have the rest of the book too.
(To:RichardJ)
It seems you still can download it here: http://www.adeptscience.co.uk/download/dlddsp/2258/0/All/Mathcad+Electronic+Book+-+Civil+Engineering+Solved+Problems.html
or even here 🙂
http://communities.ptc.com/message/30644#30644
It seems you still can download it here: http://www.adeptscience.co.uk/download/dlddsp/2258/0/All/Mathcad+Electronic+Book+-+Civil+Engineering+Solved+Problems.html ...
Yes, you can download, but only after registration on this site.
(To:VladimirN)
Thats true and registration at adeptscience is free.
The second link will work w/o registration as "mn net" is already registered wit PTC
RichardJ
(To:Werner_E)
Or even here, at the Wayback machine:
http://web.archive.org/library/ebooks/civeprobs.exe
Which you can get to via from the main library page I posted above.
This one is the .exe installer, and there are some problems getting that to run because it looks for older versions of Mathcad. It appears I posted a solution to that though, in the thread you found
http://web.archive.org/library/ebooks/civeprobs.exe ...
Richard,
That's what I have when I open this link:
(To:VladimirN)
Thats interesting. That link seems to work only if called from an appropriate archive.org site.
While I think we now have enough links and download possibilities for a handbook the original poster hadn't even asked for - go to
http://web.archive.org/web/20071115195658/http://www.mathcad.com/library/ebooks/cive_probs.asp
and choose "Download Book". Look at the link - its exactly what Richard had posted.
RichardJ
(To:Werner_E)
You beat me by one minute
(To:RichardJ)
So now we can compare the look of mathsoft site 2004 & 2007 😉 Going sentimental ...
RichardJ
(To:VladimirN)
Hmmm. You are right. Strange. Try this one, and then click on "Download Book".
http://web.archive.org/web/20040808133555/http://www.mathcad.com/library/ebooks/cive_probs.asp
Yes, now it works fine.
(To:RichardJ)
This one is the .exe installer though, and IIRC there are some problems getting that to run because it looks for older versions of Mathcad.
Yes Richard, this was the issue in the thread I referred to (http://communities.ptc.com/message/30644#30644) and you find two unpacked versions (one you posted yourself) there. Renaming the *.exe to *.zip works pretty well.
mnet
3-Newcomer
(To:mnet)
Thanks everyone. A very useful discussion regarding retrieving files from old mathsoft community. I appreciate everyone's reply.
