Unhandled exception
Linenbrink
Unhandled exception
Any theories on why I keep getting this message:
11 REPLIES 11
Give us the Mathcad file pleace!
The workbook contains proprietary data and can not be released
Have you tried re-installing the program and all its pre-requisites??
What version of Mathcad Prime are you using?
Prime 2.0
I should add...but the file was converted from Mathcad 15.0
RichardJ
(To:Linenbrink)
Can you post the worksheet?
RichardJ
(To:Linenbrink)
Then the only thing I can suggest is to delete regions, starting at the end of the worksheet and working back. When the problem goes away, you have found the offending region.
If you have current maintenance you could also send the worksheet to PTC.
thanks I'll try that
You can send the error log to PTC's technical support by creating new "Case" here ("Log a New Case" option): http://www.ptc.com/appserver/cs/case/case_logger.jsp
