Could someone please tell me what is wrong with these units. I hit the * and then inserted temp units (F)DUH ???
That's Prime... Note that many of the temperature units are functions rather than 'simple' units, due to the fact that conversion requires more than simple multiplication with a constant.
so what do I do? How do I insert units in alpha (co-eff of thermal expansion in/in*degF)
You need the delta temp, which is available in the temperature units.
What you want is change in °F (Δ°F), not °F.
OK.
But then why does it produce an error message: "This value must be a scalar or a matrix".
Short answer:
Because of poor error handling.
Slightly longer answer:
Because (as you noted) °F is a function. You can't multiply by °F for the same reason you can't multiply by any other function (numerically). You can only multiply by a scalar or matrix. The °F function can only be applied to a scalar or matrix, not multiplied by one.
Better use here R and K not F and C
Δ°F = R and Δ°C = K
The difference is merely display.
I asked my colleague from NIST why you have R in the unit of entropy, and in thermal conduction unit F. He answered that it is easier to change the US Constitution than to teach American engineers to use R in the thermal conductivity unit, rather than F.
