Hello everyone,
I want to import excel data to a table that has names and units... I'm adding the excel data and Mathcad file.
If you (in the EXCEL file) select and copy only the numbers, then paste them into Mathcad, Prime will create a table with the numbers but with un-declared variable names and units. You can then fill in the names and unit values and the table columns will work like vectors in Mathcad. An example is attached (Prime 8). Your example (with multiple columns with the same names would be challenging, and using the same calculations with a different set of data would be an issue.
It is easy to multiply the excelread statement by the expected unit.
When augmenting and stacking matrices the rows of each augment and columns of each stack should match
This gets the required matrix. It is not an input table.
Cheers
Terry
Yes, but is looks like the desired unit is mm, not m.
And as can be seen in the sheet I posted above, you have to make a compromise - either a text header or the preferred unit showing or a table without units at all 😞
Thank you all for your response. Your replies were constructive but I want to use this table's parameters in calculations, formulas,
curve formulas, etc.
Then you have to use a matrix without any text labels, just the numbers (and unit).
Prime refuses to multiply a string like "X" or "Kdata" with a number like 5.
Maybe you can come to the conclusion that you don't need a text header - the variable name of the vector can reflect its meaning and the unit is automatically shown right next to it anyway.
Single vectors are more convenient to work with anyway as opposed to a larger table (matrix) where you have to select the columns for calcs using the column selector.
When you asked for a table, I thought you would simply want is for display purposes only.
