invalid font bis
-MFra-
invalid font bis
Hello everyone,
When I start the print preview of a Mathcad 15 worksheet and I try to print it in pdf format, I receive this message:
Is it possible to determine the character that generates the error and the non-production of the pdf file?
This problem has happened to me on other occasions in the past. I ran the search excluding parts of the worksheet at each Print Preview. But it takes too much time and luck. I am looking for a faster way.
Thank you very much.
I finally found where the problem lies: it is made up of several lines of text with formulas inserted. What is the source of the non-production of the pdf file? I attach the file (it is a part of an appendix):
You can find it attached:
(To:-MFra-)
Try unchecking "Rely on system fonts only" in the settings of the AdobePDF printer
8 REPLIES 8
StuartBruff
23-Emerald V
(To:-MFra-)
Out of idle curiosity, does the attached xmcd file open in your version of Mathcad?  If so, does it have the same problem as you're currently seeing?
Stuart
-MFra-
(To:StuartBruff)
It is a file created with Mathcad 15 and has the same problem as the original file. The problem is just a few fonts.
StuartBruff
23-Emerald V
(To:-MFra-)
OK, thanks.  I'd just removed 3 rendering tags - I wondered if they had something to do with your problem.   I do note, however, that you have a mix of Times Roman, Arial and Courier fonts.   What happens if you change the Courier font to Times Roman?
Stuart
(To:StuartBruff)
I am not sure if Marcello was referring to the file YOU posted, because when I try MC refuses to open your file and I get an error message saying that the file is corrupted:
StuartBruff
23-Emerald V
(To:Werner_E)
Yes, that would be around the line I deleted.   I've quite forgotten how Mathcad 15 worksheets are encoded, so it's not surprising it can't read it (I suspected M15 might not read the file, but ...).
I don't suppose you know how Mathcad Prime 7 encodes text and math regions, do you?
Stuart
LucMeekes
(To:StuartBruff)
It's somewhat similar. But first you have to realise that a Prime .mcdx file essentially is a .zip archive. So change the extension from .mcdx to .zip and proceed from there.
-MFra-
(To:StuartBruff)
I checked the fonts just now, they are all "Times New Roman" so I don't understand where the ones you indicate come from.
Anyway, I eliminated the errors simply by pasting in Paint a keyboard printout of the page containing the bad fonts and then cutting the part of the image that interests me and pasting it in the worksheet.
(To:-MFra-)
