Mathcad Prime: Plotting Area. There is a gap below the plot where the axis expressions are which I have them hidden. Is it any chance to eliminate the gap?
thanks,
Eleni
thanks,
Eleni
Guess - no.
But you can overlap that area with the following regions. That way it looks better when printed but may be harder to edit later.
You also can give the chart component a try - it has a lot of drawbacks so I don't/can't use it, but maybe it solves your problem.
thanks,
Eleni
Guess - no.
thanks
You can move x axis function to right position.
Yes, good idea. I forgot about that possibility.
