RESPECTED SIR,
I am the user of student version of CREO 10.00. I installed the software the error is occurs that software not detecting some technical data. There is attachment. Please solve this problem as early as possible.
But when I installed student version CREO 9.00 that time this problem had not occured. In same laptop I had installed it. So please as early as possible please solve this problem. OR give another solution.
Similar problem:
Check whether "C:\Program Files\PTC\DiagnosticTools\x86e_win64\obj\qualityagent.exe" does exist.
If the file exists then:
quality_agent_path C:\Program Files\PTC\DiagnosticTools\x86e_win64\obj\qualityagent.exe
Note:
Read https://community.ptc.com/t5/System-Administration/Issues-Using-Creo-10-0-Student-Edition/m-p/929474 discussion.
Message related to Java is not important ... Creo will run even without Java.
