Licensing Error Creo 7.0.2.0
  • January 20, 2021
  • 2 replies
  • 4097 views
I'm trying to download, install, and use the student version of creo parametric. I successfully downloaded it 3 times now but each time had an error "0x06000012" when trying to run the software each time. I deleted everything again to try and resintall but now I'm getting a license issue. I'm trying to use Creo 7.0.2.0, with the license code BK700908EDSTUDENTEDUNI and when I hit install licensing it says "Error!"
    Hi @TZ_9789274
    For error 0x6000012
    • Uninstall PTC Quality Agent from Control Panel > Programs and Features
    • Re-install the PTC Quality Agent using qualityagent_64.msi file from install > addon folder from the downloaded cd image.
    I hope this helps.
    Vipul
