Feb 5, 2024 9:02 PM UTC
Issues Using Creo 10.0 Student Edition
I am having an issue accessing Creo 10.0. I had Creo 9.0 but had to update due to my files upgrading from 9 to 10 on my new laptop, so my old laptop running 9.0 could no longer open these files. I attempted downloading creo 10.0 using my schools access, however I am running into an error I do not understand, a screenshot is provided below.
Feb 6, 2024 10:11 AM UTC
1.] uninstall PTC Quality Agent item
2.] install it using CR10_install_package\install\addon\qualityagent_64.msi
Feb 5, 2024 9:19 PM UTC
Did you do a clean install of Creo 10 on your laptop by removing Creo 9 first?
The Quality Agent is under the loadpoint in the Creo/Agent folder.
Feb 5, 2024 9:45 PM UTC
Yes, At first I attempted upgrading to Creo 10.0 but that gave me a licensing error, I immediately then wiped my computer of anything Creo related and tried a fresh install and am now receiving this error.
Feb 6, 2024 3:19 PM UTC
Where do I find the quality agent to uninstall it? I cannot seem to find it.
Feb 12, 2024 6:35 PM UTC
@MO_10765744 wrote:
Okay, I have done a instructed and received the following error when attempting to save the config file.
here first is the screenshot of the qualityagent file you asked to see, I believe this is what I'm supposed to see:
and here is the issue I am having when trying to save the file:
1st screenshot is OK.
2nd screenshot contains following window:
Click Yes button. This will save the config.pro.txt file in Documents folder.
Turn on File name extension option as shown on following picture.
Instead of config.pro name you will see real filename ... config.pro.txt
Please remove .txt extension ... correct filename is config.pro
Last step ... copy config.pro from Documents folder to C:\Program Files\PTC\Creo 10.0.0.0\Common Files\text folder.Some dialogs will appear... allow saving the file.
