Creo 8 Intsall
HS_10928676
2-Explorer
Creo 8 Intsall
Hello everyone,
I am having trouble installing Creo 8 on my Dell XPS 15, i already turned off al anti virus software but the setup file still wont open and run on my laptop.
Any Solution ideas?
Thank you in advance!
7 REPLIES 7
Take a look here - "Running setup.exe does nothing - Creo 8.0": https://community.ptc.com/t5/PTC-Education-Forum/running-setup-exe-does-nothing-Creo-8-0/td-p/793740
Thanks bit doesnt seem to work for me 😞
1.) did you unzip installatin zip file (5 GB size) into new directory?
2.) what is the path to setup.exe?
Martin Hanák
Yes i unzipped it and the path is
c:\Users\suman\Desktop\CAD
  • open Command prompt window
  • cd /D c:\Users\suman\Desktop\CAD
  • setup.exe
  • hopefully you will see some error message
  • you can also open Event viewer and search for error message related to setup.exe startup time
You can also create new admin account, login and run setup.exe.
Does suman user belong to admins?
Martin Hanák
Yes suman should habe admin and i opened the event viewer it says that the error ID is: 0x0x3110
I am sorry I do not know what 0x3110 error means.
Create new admin account, login and run setup.exe
Martin Hanák
