Noteworthy April 2021 Posts
ENGAGE= KUDO, REPLY, or SOLVE!
Below are the top engaging PTC Community threads for April! See if your community username made this list! Or, read more about a topic that interests you!
1. Creo: @seanmcdonn revitalized the 2014 conversation Creo Parameters and Drawing Text Formatting started by @BreMiSt
Thank you, @dschenken @StephenW @TomU @dgschaefer @dbaum @gbronke @dnordin @pausob for participating!
2. Creo: @msteffke received an Accepted Solution from @RPN for his thread ProSelection Array without user interaction. Thank you, @FV for participating!
3. ThingWorx: @MFritzhand received an Accepted Solution for the inquiry JSON to InfoTable
https://community.ptc.com/t5/ThingWorx-Developers/JSON-to-InfoTable/m-p/723937#M51554
4. ThingWorx : @SG_9012314 received help with a ThingWorx Installation with postgreSQL for windows
https://community.ptc.com/t5/ThingWorx-Developers/Thingworx-installation/m-p/724267
5. ThingWorx: @ML_8931370 asked about Error installation ThingWorx Foundation 9.1
6. ThingWorx: @JanKerkhofs asked about QR Code Extension on Marketplace?
https://community.ptc.com/t5/ThingWorx-Developers/QR-Code-Extension-on-Marketplace/m-p/724673
7. Vuforia: @ASM asked about Multiple scan widget in 3D eyewear
@whity and @dsgnrClarK thank you for participating to the conversation!
https://community.ptc.com/t5/Vuforia-Studio/Multiple-scan-widget-in-3D-eyewear/m-p/726687
8. Vuforia: @Ace_Rothstein received and Accepted Solution for the inquiry How to create a fade in and fade out effect for a 3D Image when it is triggered for visibility.
9. Vuforia: @EEmmanuelLG received an Accepted Solution for the issue around Can’t sign in VEC with organization account in HoloLens
10. Windchill: @khimani_mohiki received an Accepted Solution from @d_graham for the inquiry related to Creating, Storing & sharing Drawings
https://community.ptc.com/t5/Windchill/Creating-Storing-amp-sharing-Drawings/m-p/724369#M63858
Thank you, @BenLoosli and @avillanueva for also contributing to the conversation!
11. Windchill: @SV_9649587 received a “swift response” from @Ajit_Kulkarni on how to Publish PDF to drawing content as attachment
Thank you, @d_graham for participating also in the conversation!
https://community.ptc.com/t5/Windchill/Publish-PDF-to-drawing-content-as-attachement/m-p/722545
12. Windchill: @arajagopal @joe_morton @BenLoosli @mmeadows-3 @mmeadows-3 and @rhart
had a conversation around EPMDocument subtyping.
https://community.ptc.com/t5/Windchill/EPMDocument-subtyping/m-p/725401
13. Windchill: @aachanta received an Accepted Solution from @BenPerry for the inquiry around Windchill API to check if a certain version of object is published or not and then publish
Another great contribution from d_graham as well!
14. Windchill: @SvenVanDroogenb received an Accepted Solution from @d_graham for Routing/Tallying Expression in Assigned Activity
https://community.ptc.com/t5/Windchill/Routing-Tallying-Expression-in-Assigned-Activity/m-p/725334#M63885
15. Arbortext: @BE_9902721 received help from @bfriesen for IsoDraw 7.3 does not show colors when importing CGM
https://community.ptc.com/t5/Arbortext/IsoDraw-7-3-does-not-show-colors-when-importing-CGM/m-p/724278
16. Arbortext: @Tusken_Raider @Tusken_Raider received help from @DmitryTsarev Using HTTPS/SSL to connect to Arbortext Publishing Engine
17. Arbortext: @Tusken_Raider received some insight from @GarethOakes and @DmitryTsarev about Error AutoNumber Action Failed Number of conflicts
https://community.ptc.com/t5/Arbortext/Has-anyone-seen-this-error/m-p/723144
18. Windchill SSE: @amatai revitalized the topic Message: system clipboard data unavailable originally started by @wcatunda-2
Thank you, @Ted_Lin @fbamberg and @einsor for contributing to the conversation!
19. Windchill SSE: @BaluSri received a reply from @kjain2 Assignment trigger meant to clear rich-text is configured with MKS HTML tag and a non-breaking space
https://community.ptc.com/t5/Windchill-Systems-Software/Assignment-trigger-meant-to-clear-rich-text-is-configured-with/m-p/724419
20. Mathcad: @Cornel received an Accepted Solution from @Werner_E to his topic related to Matlab Code to Mathcad (15) – FE
Thank you @terryhendicott for also contributing to the thread!
https://community.ptc.com/t5/PTC-Mathcad/Matlab-Code-to-Mathcad-15-FE/m-p/725409
21. Mathcad: We can always count on @Fred_Kohlhepp to provide some FUN to Mathcad forums with his Just for fun, hovering helicopter post.
https://community.ptc.com/t5/PTC-Mathcad/Just-for-fun-hovering-helicopter/m-p/723289
22. Mathcad: @prop_design gave a shout out to other community members for helping with the Two Square Wave Vibration Examples post. Awesome Teamwork!
Special recognition to contributors @-MFra- and @LucMeekes
https://community.ptc.com/t5/PTC-Mathcad/Two-Square-Wave-Vibration-Examples/m-p/725382
