Apr 14, 2021 11:40 AM UTC
Thingworx installation
i'm installing thinworx with postgreSQL for windows. I follow the guide starting from TOMCAT but as soon as i run tomcat.exe no licence file is crated in the folder that i create in the root C:\ThingworxPlatform.
tdixitAnswer
Apr 29, 2021 6:53 AM UTC
Hello @SG_9012314
Ideally you shouldn't delete the folders first rather you need to run the uninstaller and that would have automatically delete all the folder
But no issues. Now, first you have to make sure all previous ThingWorx folder, services has been completely deleted. You need to create a new Database again.
Then follow the steps as mentioned in the below guide and let me know if it works or not
https://support.ptc.com/help/thingworx/platform/r9/en/index.html#page/ThingWorx%2FHelp%2FInstallation%2FThingWorxInstallers.html%23
Toolika Dixit
Apr 14, 2021 1:34 PM UTC
Hi @SG_9012314
Thank you reaching out to PTC.
Could you please help me with below details
  • Please confirm which ThingWorx version are you trying to install
  • Is it a manual installation or through ThingWorx foundation installer
  • If the ThingWorx has been installed. Kindly share the ThingWorx logs present at location <ThingWorxInstallationDirectory>/ThingWorxStorage/Logs and Tomcat logs
Toolika Dixit
Apr 14, 2021 3:17 PM UTC
i've tried both; the state of the art is that i cannot finish the installation with the foundation installer because it doesn't fine the correct license.bin
Apr 15, 2021 5:55 AM UTC
Hi @SG_9012314
Could you please let me know what all files are present in ThingWorx Platform folder ?
Toolika Dixit
Support
Apr 27, 2021 3:19 PM UTC
Hi @SG_9012314.
Have you been successful in applying a new license?  If so, please mark the previous response as the Accepted Solution for the benefit of others in the community.
If you are still having issues, please let us know.
--Sharon
Apr 28, 2021 1:27 PM UTC
no i didn't solve.
attached my log file.
Apr 29, 2021 6:21 AM UTC
Hi @SG_9012314
I believe earlier you were able to install ThingWorx and the issue was with applying the License file.
Have you uninstalled everything and now again you are doing the installation.
If not, could you please help with the ThingWorx logs present at ThingWorxStorage/Logs directory
Toolika Dixit
Support
May 10, 2021 6:48 PM UTC
Hi @SG_9012314.
If you have resolved your issue, please mark the appropriate response as the Accepted Solution or post a reply with the solution you found and mark that as the Accepted Solution.  This will help other community members who encounter the same issue.
--Sharon
