JSON to InfoTable
Hello, I followed various articles from community forum here as well as this TWX article. and I am still having issues with my code outputting to an InfoTable. I am using an API to fetch Stock Price JSON data and having it be converted to an InfoTable, so it can be displayed into a graph in Mashups.
I've attached screenshots of my DataShape Field Definitions as well as the JSON Data Output.
The TWX code, with it outputting the columns with "No Data" is below. I've tried playing around with the for loop and doing a data.array.length but that mentions length is undefined. I am not sure if that would output to it being an InfoTable either. Thank you.
var restParams = {
 proxyScheme: undefined /* STRING */,
 headers: undefined /* JSON */,
 ignoreSSLErrors: true /* BOOLEAN */,
 useNTLM: undefined /* BOOLEAN */,
 workstation: undefined /* STRING */,
 useProxy: undefined /* BOOLEAN */,
 withCookies: undefined /* BOOLEAN */,
 proxyHost: undefined /* STRING */,
 url: "https://finnhub.io/api/v1/quote?symbol=AAPL&token=c1mbi3i37fkpnsp59e6g" /* STRING */,
 content: undefined /* JSON */,
 timeout: undefined /* NUMBER */,
 proxyPort: undefined /* INTEGER */,
 password: undefined /* STRING */,
 domain: undefined /* STRING */,
 username: undefined /* STRING */
// result: JSON
var data = Resources["ContentLoaderFunctions"].GetJSON(restParams);
var params = {
infoTableName: "InfoTable" /* STRING */,
dataShapeName: "GrahicVisualizer_Stock_DS" /* DATASHAPENAME */
// result: INFOTABLE
var jsonTable = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(params);
//var tableLength = CobotInfoTable.rows.length;
//fix code below
for(var i=0;i<data.length;i++)
jsonTable.AddRow({
 c:data.c,
 h:data.h,
 l:data.l,
 o:data.o,
 pc:data.pc,
 t:data.t
result = jsonTable;
@tdixit ,
I managed to solve the issue on my end. InfoTable really only function with arrays, that is why all the solutions on forums I were seeing here were mentioning the for loop to parse it. The API I was pulling from used just one specific object, so I was unable to turn that into an array.
Through trial and error, I tried Stringify method, which didn't work really. I then proceeded utilizing Parse method. This achieved getting each number within the object by itself. I set a variable for each number. I was able to call each specific number... from there I tried converting to infotable using the AddRow snippet. Encountered an error, "unable to convert DOUBLE to JSON". I thought okay... I switched the datatypes on the datashape field defintions to number, so Double can be converted. I ran it, was successful.
me.myjson = Resources["ContentLoaderFunctions"].GetJSON(params);
var myJSON = JSON.parse(me.myjson);
//result = data;
//result = myJSON;
var currentPrice = me.myjson.c;
var highPrice = me.myjson.h;
var lowPrice = me.myjson.l;
var openPrice = me.myjson.o;
var previousClose = me.myjson.pc;
var timeStamp = me.myjson.t;
var params = {
 infoTableName : "InfoTable",
 dataShapeName : "GrahicVisualizer_Stock_DS"
// CreateInfoTableFromDataShape(infoTableName:STRING("InfoTable"), dataShapeName:STRING):INFOTABLE(GrahicVisualizer_Stock_DS)
var infoTable = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(params);
var newRow = new Object();
newRow.c = currentPrice;
newRow.h = highPrice;
newRow.l = lowPrice;
newRow.o = openPrice;
newRow.pc = previousClose;
newRow.t = timeStamp;
infoTable.AddRow(newRow);
result = infoTable;
Hello @MFritzhand
Thank you for reaching out to PTC
I will try this at my end and will get back to you.
Meanwhile could you please help me with your ThingWorx version
Toolika Dixit
I am on TWX 9.0 @tdixit
MFritzhand1-VisitorAuthorAnswer
@tdixit ,
//result = data;
//result = myJSON;
var params = {
result = infoTable;
