See the Top Community Engagers and the Top Noteworthy posts for the month of March.
Top March 2023 Community Engagers:
@WernerE @HelesicPetr @MartinHanak @tbraxton @avillanueva @Constantine @jensc @VladimirN @StephenW @ttokoro @LucMeekes @d_graham @kdirth @Eike_Hauptmann @Patriot_1776 @BenLoosli @abrinks @SweetPeasHub @terryhendicott @Sathishkumar_C
MOST NOTEWORTHY POSTS
Below are some of the top engaging or most viewed PTC Community topic threads for March 2023! See if your community username made this list! Or, read more about a topic that interests you!
1. Creo: @JA_1434743 asked about Working with more sessions in Creo8. Great contributions by @MartinHanak, @StephenW, @RandyJones.
2. Creo: Adam_048 received an accepted solution from LukMazur for topic "is there a way to show driving dimensions which "origin" extension lines get clipped by x-sections?". Thank you!
3. Creo: Thank you SweetPeasHub for providing an accepted solution for JeffreySabala on this topic - Creo Simulate using saved autogem meshes in top assembly
5. Creo: A question about New PC for large assemblies was posted by Chris3 and an Accepted Solution was provided by rreifsnyder. Thank you TrainStopper also for your contribution!
https://community.ptc.com/t5/System-Administration/New-PC-for-large-assemblies/m-p/865065#M29373
6. ThingWorx: @bchaudharygave an Accepted Solution to jgp for the topic Limit of number of properties in the Composer viewer.
7. ThingWorx: The topic Flexible containers posted by jensc received an accepted solution provided by
https://community.ptc.com/t5/ThingWorx-Developers/Flexible-containers/m-p/861132#M61523
8. ThingWorx: Velkumar provided a speedy response and Accepted Solution to the inquiry by Hariharasuthan about the topic "i have services code but how to implement schedulers"
9. ThingWorx: ZbigniewK asked about User permissions for timers and nmutter provided a quick Accepted Solution.
https://community.ptc.com/t5/ThingWorx-Developers/User-permissions-for-timers/m-p/864544#M61705
10. ThingWorx: MR_10404102 posted the topic Finding data in json from an infotable and received an Accepted Solution from Sathishkumar_C.
11. Vuforia: emmanuel001 shared a post about don´t show symbol in my animation. Thank you ClayHelberg for providing an Accepted Solution!
https://community.ptc.com/t5/Vuforia-Studio/don-t-show-symbol-in-my-animation/m-p/862939#M11596
12. Vuforia: MattBob wanted to Invoke reset tracking Vuforia View function
Thanks RolandRaytchev for contributing with the Accepted Solution!
13. Windchill: rburk posted the topic Windchill Task error and received an Accepted Solution by HelesicPetr.
Thank you d_graham and Dobi for your contribution!
https://community.ptc.com/t5/Windchill/Windchill-Task-error/m-p/864076#M70825
14. Windchill: AThomas104 asked How to check in drawings to windchill ? and avillanueva provided the Accepted Solution. Thank you HelesicPetr and BenLoosli for your contributions as well.
https://community.ptc.com/t5/Windchill/How-to-check-in-drawings-to-windchill/m-p/864094#M70829
15. Windhill: Dobi asked about Add an attribute display field by "state" with an Acccepted Solution from d_graham
16. Windchill: nbojcetic asked about Problem getting CSRF_NONCE value (HTTP 400)
and HelesicPetr provided an Accepted Solution!
https://community.ptc.com/t5/Windchill/Problem-getting-CSRF-NONCE-value-HTTP-400/m-p/863664#M70794
17. Windchill: MV_10441462 asked a question about the Best way to download files from Windchill Server to client HelesicPetr delivered an Accepted Solution. Thank you avillanueva for participating!
18. Mathcad: JC_10225320 needed help with Inverse trig function and ttokoro provided the Accepted Solution!
https://community.ptc.com/t5/Mathcad/Inverse-trig-function/m-p/865540#M205859
19. Mathcad: AS_10562569 needed thelp with this topic This Value Must be A Real Number When Plotting Functions and Werner_E helped with an Accepted Solution. Thank you ttokoro, TH_10592087 and terryhendicott for participating as well!
20. Arbortext: Toolbars from IsoDraw 7.3 to 7.4 was khoward's topic, which received an Accepted Solution from bfriesen.Thank you!
https://community.ptc.com/t5/Arbortext/Toolbars-from-IsoDraw-7-3-to-7-4/m-p/861776#M32832
