PTC Community Monthly Stand-Out October 2023
achirila
Emeritus
See the Top Community Engagers and the Top Noteworthy posts for the month of October..
Top October 2023 Community Engagers:
@HelesicPetr @Werner_E @MartinHanak @Velkumar @tbraxton @StephenW @avillanueva @LucMeekes @BenLoosli @ttokoro @KenFarley @terryhendicott @Dobi @RPN @kdirth @JJ_10814212 @Dale_Rosema @Pettersson @VladimirN @VladimirRosu @KN_9954684 @rleir @SweetPeasHub
MOST NOTEWORTHY POSTS
Below are some of the top engaging or most viewed PTC Community topic threads for October 2023!  See if your community username made this list! Or, read more about a topic that interests you!
1. Creo: DW_8671498  asked about Drawing ask for PRT template. Solution was provided by kdirth
https://community.ptc.com/t5/3D-Part-Assembly-Design/Drawing-ask-for-PRT-template/m-p/909509#M131848
2. Creo: anthonyws received an accepted solution from  for topic drawing BOM of assembly from imported STP file. Thank you eden60, for your contributions as well.
https://community.ptc.com/t5/3D-Part-Assembly-Design/drawing-BOM-of-assembly-from-imported-STP-file/m-p/903819#M131438
3. Creo: Thank you for providing an accepted solution for D_Hale on this topic Assembly Pattern Mass Properties.
https://community.ptc.com/t5/Analysis/Assembly-Pattern-Mass-Properties/m-p/908735#M11695
4. Creo: KG_7681027 needed help with this topic - Creo Simulate 8.0.8.0 Determine Max Force up to Yield Point and ChrisKaswer offered him an accepted solution. Thank you SweetPeasHub for your contributions.
https://community.ptc.com/t5/Analysis/Creo-Simulate-8-0-8-0-Determine-Max-Force-up-to-Yield-Point/m-p/908706#M11691
5. Creo: A question about Dependency of the Toolkit DLL on other DLLs (e.g. open source libraries) was posted by DomenicLaritz and an Accepted Solution was provided by RPN. Thank you YaroslavSin for your contributions as well!
https://community.ptc.com/t5/Customization/Dependency-of-the-Toolkit-DLL-on-other-DLLs-e-g-open-source/m-p/908045#M12500
6. ThingWorx:  gave an Accepted Solution to DUlinic for the topic Project package does not include all the entities in the project.
https://community.ptc.com/t5/ThingWorx-Developers/Project-package-does-not-include-all-the-entities-in-the-project/m-p/909345#M64266
7. ThingWorx: The topic Template literals cant use in thingworx posted by LeoChen received an accepted solution provided by rogerjn. Thank you odukiya, PEHOWE for your contributions as well.
https://community.ptc.com/t5/ThingWorx-Developers/Template-literals-cant-use-in-thingworx/m-p/909109#M64247
8. ThingWorx: Velkumar provided a speedy response and Accepted Solution to the inquiry by KN_9954684 about Mashup migration.
https://community.ptc.com/t5/ThingWorx-Developers/Mashup-migration/m-p/909486#M64275
9. ThingWorx: Socka_HW had an issue with Following attributes in ThingWorx (TWx) Flow, for IBM Doors Next Gen to connect to TWx Flow and rleir provided a quick Accepted Solution.
https://community.ptc.com/t5/ThingWorx-Developers/Following-attributes-in-ThingWorx-TWx-Flow-for-IBM-Doors-Next/m-p/909229#M64277
10. ThingWorx: SC_10151701 posted the topic How to make https REST API calls from Thingworx to another application and received an Accepted Solution from Velkumar.
https://community.ptc.com/t5/ThingWorx-Developers/How-to-make-https-REST-API-calls-from-Thingworx-to-another/m-p/906734#M64115
11. Vuforia: Aditya1702 shared a post about Thingworx for Vuforia Studio.
Thank you  for providing an Accepted Solution!
https://community.ptc.com/t5/Vuforia-Studio/Thingworx-for-Vuforia-Studio/m-p/905952#M12050
12. Vuforia: jmikesell posted the topic How to set image source from JS
and received an Accepted Solution from ytella
13. Windchill: libo-ME posted the topic I want to checkin an assembly 3d model to a new baseline and received an Accepted Solution by jbailey.
https://community.ptc.com/t5/Windchill/I-want-checkin-a-assembly-3d-model-to-a-new-baseline/m-p/909075#M75537
14. Windchill: Ben_A asked about the Duplicate Problem Report and d_graham
provided the Accepted Solution.
https://community.ptc.com/t5/Windchill/Duplicate-Problem-Report/m-p/909276#M75593
15. Windhill: YZ_10818805 asked about Export work flow with error with an Acccepted Solution from Rocket_. Thank you  for your contribution!
https://community.ptc.com/t5/Windchill/Export-work-flow-with-error/m-p/908860#M75512
16. Windchill: AB_9905442 asked about Get programmatically Version History of document and  provided an Accepted Solution!
https://community.ptc.com/t5/Windchill/Get-programmatically-Version-History-of-document/m-p/909136#M75556
17. Mathcad: Sergey needed help with Symbolic operations with complex functions: conjugate, Re and Im and  provided the Accepted Solution! Thank you ttokoro,  for your contributions!
https://community.ptc.com/t5/Mathcad/Symbolic-operations-with-complex-functions-conjugate-Re-and-Im/m-p/909267#M209200
18. Mathcad: tuongpv_vf needed with Support convert file to Mathcad prime 8
and  helped with an Accepted Solution.
https://community.ptc.com/t5/Mathcad/Support-convert-file-to-Mathcad-prime-8/m-p/909344#M209208
19. Mathcad: CarlosRomero asked about Anneal application in optimization and  provided the Accepted Solution.
https://community.ptc.com/t5/Mathcad/Anneal-application-in-optimization/m-p/907868#M209069
20. Mathcad: PB_10827347 asked about Solve to a ratio with an Acccepted Solution from ttokoro. Thank you  for your contribution!
https://community.ptc.com/t5/Mathcad/Solve-to-a-ratio/m-p/907418#M209043
Andra
0 REPLIES 0
