Oct 30, 2023 10:00 AM UTC
Get programmatically Version History of document
Hello ,
I want to display some data regarding Version History of document  (WINDCHILL 11)
version , file name , state , comments ,modified by and last modified
HelesicPetr
Nov 1, 2023 9:08 AM UTC
Hi @AB_9905442
btw the VersionControlHelper contains an other method that returns all iterations. allIterationsFrom
try
	WTDocument document = getDocumentByNumber("0000000142");
	QueryResult allVersions = VersionControlHelper.service.allIterationsFrom(document);
	while (allVersions.hasMoreElements())
		Object obj = allVersions.nextElement();
		if (obj instanceof RevisionControlled)
			RevisionControlled iterationObject = (RevisionControlled) obj;
			System.out.printf("numer> %s - name> %s - version> %s %n", iterationObject.getDisplayIdentifier(), iterationObject.getName(), iterationObject.getIterationDisplayIdentifier());
} catch (QueryException e)
	e.printStackTrace();
} catch (WTException e)
PetrH
HelesicPetr
Oct 30, 2023 12:11 PM UTC
Hi @AB_9905442
You can try this method that returns all versions so the history is based on all version.
Information can be collected from each object that is returned in a query...
QueryResult allVersions = VersionControlHelper.service.allVersionsOf(document);
then you can use following methods to get some info..
iterationObject.getCreateTimestamp();
iterationObject.getCreator();
iterationObject.getModifier();
iterationObject.getVersionDisplayIdentifier();
 the document variable can be Mater object or any Versioned one.
example
WTDocument or WTDocumentMaster
EPMDocument or EPMDocumentMaster
PetrH
Oct 31, 2023 8:59 AM UTC
Hello ,
Thank you for the methode , but it display only 2 iteration
Oct 31, 2023 9:06 AM UTC
 this is our example
joe_morton
Oct 30, 2023 7:07 PM UTC
Have you used they Query Builder before? You could create a query to display this information
Some info to help you get started: https://www.ptc.com/en/support/wnc-reporting-landing/wnc-reporting-landing-main/querybuilder-intro/qb-intro?overlay=BDDBFF62-6C2F-436C-A38B-BF1BDD6B3F23&source=search
Oct 30, 2023 7:50 PM UTC
Programmatically as in an external program making REST OData API calls? Or an external program making REST calls for QB data? Or a program integrated in the WC server?
Oct 31, 2023 9:01 AM UTC
Hello @rleir ,
A methode like  the first comment
HelesicPetr
Hi @AB_9905442
And is it wrong? why? you didn't provide real data if there are just versions A.1 and B.1 the result is correct.
PetrH
Oct 31, 2023 9:14 AM UTC
I implemented this methode  it's ok but the first iteration not exist ( A1)
 WTDocument refreshedDoc = (WTDocument) PersistenceHelper.manager.refresh(document);
	 // Get the version history
	 QueryResult versionHistory = VersionControlHelper.service.allIterationsOf(refreshedDoc.getMaster());
	 // Display the version history information
	 int i=1;
	 while (versionHistory.hasMoreElements()) {
	 	String iteration="";
	 	String version="";
	 	String fileName="";
	 	String state="";
	 	String coments="";
	 	String modifyBy="";
	 	String lastModified="";
	 Object versioned = versionHistory.nextElement();
	 if (versioned instanceof Iterated) {
	 Iterated iterated = (Iterated) versioned;
	 iteration = getVersion(iterated);
	 IterationInfo iterationInfo = iterated.getIterationInfo();
	 coments=iterationInfo.getNote();
	 modifyBy= iterationInfo.getModifier().getFullName();
	 // taskLogger.debug("iteration: " + iteration);
	 // taskLogger.debug("getModifierName: " + iterated.getModifierName());
	 modifyBy=iterated.getModifierName();
	 lastModified=iterated.getCreatorName();
	 if (iterated instanceof LifeCycleManaged) {
	 LifeCycleManaged lifeCycleManaged = (LifeCycleManaged) iterated;
	 state= lifeCycleManaged.getLifeCycleState().toString();
	 //taskLogger.debug("state: " + state);
	 if (iterated instanceof WTDocument) {
	 WTDocument doc = (WTDocument) iterated;
	 //taskLogger.debug("doc: " + doc.getNumber());
	 ContentHolder holder= ContentHelper.service.getContents(doc);
	 ContentItem ci = ContentHelper.getPrimary((FormatContentHolder) holder);
	 ApplicationData ad = (ApplicationData) ci;
	 fileName = ad.getFileName();
	 //taskLogger.debug(doc.getIterationInfo().getIdentifier().getValue());
	 // taskLogger.debug(doc.getVersionInfo().getIdentifier().getValue());
	 version=doc.getVersionInfo().getIdentifier().getValue();
	 taskLogger.debug("----------------------"+i+"---------------------------------");
	 taskLogger.debug(version+iteration+"---"+fileName+"---"+state+"---"+coments+"---"+modifyBy+"---"+lastModified);
	 i++;
how can i display also A1 iteration
HelesicPetr
Oct 31, 2023 9:21 AM UTC
@AB_9905442
I've already answered.
PetrH
